Lenovo 320-14iap no power needed bios `
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Lenovo ideapad 320-14iap
    dg424/dg524 nm-b301
    rev 1.0
    2017-03-09
    no shorted coils i think bios problem or ec
    backup also here
  • peste
    • 13721
    • ROMANIA
    Re: Lenovo no power needed bios `
    try post#4...
    https://www.badcaps.net/forum/showthread.php?p=900975
    • kalilinux25
      • Mar 2018
      • 2093
      • ZAMBOANGA SIBUGAY
      Originally posted by peste
      tried it sir no power
        • 22087
        The bios linked to by peste is good,test all voltage and signals on page 48 of the schemmatic.
        https://www.badcaps.net/forum/showthread.php?p=907334
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          Hi sir can you please check my bios it for
          DG424/DG524 NM-B301 REV 1.0
          2017-03-09
          motherboard cpu is
          SR2Z6 Intel Celeron N3450
          SERIAL NUMBER PF12DQM0
          LENOVO 320-14IAP
          Please check if my bios is back or need clean sir update
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            Originally posted by kalilinux25
            Hi sir can you please check my bios it for badly need it to clean its me region
            2017-03-09
            motherboard cpu is
            LENOVO 320-14IAP
            it my backup
            Hope someone can clean this bin and clean me region also.
              • 22087
              If you must post images post them on badcaps please.
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                ok noted .
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  I taught I need to use other link for images, now I know so I can use the badcaps
                  • kalilinux25
                    • Mar 2018
                    • 2093
                    • ZAMBOANGA SIBUGAY
                    Why if I used a latest bin from official website it wont power the board? Do I need also to flash the EC bin? , but if I put back the original bin it will power the board , but it has a issue stock on windows loading screen even live os is tested.
                    this is the ME Analayzer showing the backup bin
                      • 22087
                      320-14IAP Laptop (ideapad) - Type 80XQ 5RCN**WW
                      Flash the bios and EC -> https://www.badcaps.net/forum/showpo...78&postcount=4
                      Copy your DMI from your backup using the attached CopyDMI script .
                      Copy DMI info easily with Hex editing software and Macro script: https://www.badcaps.net/forum/showthread.php?p=1214739
                      0x0421000 - 0x0422FFF
                      • kalilinux25
                        • Mar 2018
                        • 2093
                        • ZAMBOANGA SIBUGAY
                        Thanks sir wwhat a great help Ill test it again sir after 2 days
                        • kalilinux25
                          • Mar 2018
                          • 2093
                          • ZAMBOANGA SIBUGAY
                          Re: Lenovo 320-14iap no power needed bios `
                          Update regardign about this unit it was not about the bios it was a very tiny rust in the ec chip , I really need to invest a microscope now a days, but thanks for this
                          • Duranitron
                            • Jul 2014
                            • 544
                            • Philippines
                            I need help guys, Need bios dump of dg424 dg524 nm b301 rev 1.0 attached is my backup bios,
                            need clean ME.
                            Model no: LCM 16H5
                            Lenovo P/N : SN20M61837
                            I can't find the serial number. There is no bottom plate label in the laptop
                            FYI: I attempted to extract data from my device using an EZP-2010 programmer, both with and without a 1.8V adapter.
                            Comparing the extracted BIOS files using WinMerge, they were identical. .
                            Thank you in advance.
                            • shiyab
                              • Sep 2023
                              • 1646
                              • india
                              need clean ME.
                              Model no: LCM 16H5
                              hi try
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                Originally posted by shiyab
                                hi try
                                Thank you bro. Hope it works. Post the result later..
                                  • 22087
                                  need clean ME.
                                  Model no: LCM 16H5
                                  Posts moved to 320-14iap thread. Your model and serial 320-14IAP Laptop (ideapad) - Type 80XQ , S/N PF0W4B0H
                                  This bios has your DMI info ,SN etc.
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    Thank you very much SMDFlea! Gonna try it and post the result here.
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      Thank you very much SMDFlea! You're a life saver! Your bios works like a charm.. All voltage are correct 5v, 3.3v, 1.8v in bios..Gonna test again
                                        SMDFlea commented
                                        Editing a comment
                                        You`re welcome :-)
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • Wahaz
                                      by Wahaz
                                      10-30-2023, 08:42 PM
                                    • grimacelord
                                      by grimacelord
                                      Hello there.
                                      History:
                                      03-15-2023, 03:29 PM
                                    • to5it0
                                      by to5it0
                                      10-24-2025, 01:35 AM
                                    • mkdj
                                      Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                      by mkdj
                                      Dear all,
                                      I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                      Here the steps I have taken to fix the laptop:
                                      - downloaded latest BIOS from Lenovo Website...
                                      10-18-2025, 03:43 AM
